\"Rubber?\" degradation...
D
Don Y
The most important ergonomic design criteria that my
testers report is \"wipe clean\" -- for all exposed surfaces
(appliances, controls, etc.).
OK, that puts limits on the types of textured surfaces that
can be used -- but that\'s not unsurmountable.
I heard lots of complaints of hand-held/operated devices that
\"feel sticky\" after a while. I had assumed this was just a
buildup of oils/dirt from hands, easily addressed if the surface
was designed for ease of cleaning (many devices have silly nooks
and crannies that are often unnecessary or cosmetic).
But, I\'ve heard from several people that many devices *can\'t* be
cleaned. Or, more exactly, that cleaning doesn\'t remove the
\"stickiness\". (?)
I received a couple of such samples in the past week and
they *are* sticky. And, it doesn\'t appear to be something
that was \"applied\" (even accidentally) by user/use. it didn\'t
wipe clean with mild detergent and water. Or alcohol.
[I was reluctant to try more aggressive solvents for fear of
damaging items that I don\'t own!]
So, I spent the day digging through piles of kit at one of
the non-profits with which I\'m affiliated. And, managed to
find an assortment of similarly \"sticky\" surfaces (some that
see human contact, others that are NOT intended to see contact!)
I\'ve found these to have a coating (?) that is responsible
for the stickiness. And, that the coating appears to *develop*
this stickiness -- it\'s not present in all instances of an object
(age?).
With a LITTLE elbow grease and alcohol, I am able to remove the
coating and expose the \"solid plastic\" beneath. The stickiness
disappears with the coating\'s removal.
I recall having problems with \"rubber\" feet disintegrating
on various devices (e.g., all of my Sun enclosures now have
self-adhesive *felt* feet as a precaution against their
original feet turning to GOO and damaging the finish of the
bits of furniture on which they reside).
And, prompted by today\'s exercise, I noticed that the \"rubber\"
button to operate my electric toothbrush is becoming \"sticky\";
as if losing its chemical integrity.
I assume these other \"sticky\" items have a fine coat of a
similar substance applied to their HARD PLASTIC surfaces...
for \"feel\"?
So:
- what causes this?
- is there anything to prevent it\'s occurrence?
- why would manufacturers go this route if this was an expected outcome?
- are there other alternatives to alter feel/appearance without such
applications? (mild textures?)
On Wednesday, June 7, 2023 at 3:39:26 PM UTC+10, Don Y wrote:
Rubber is polyisoprene.
https://en.wikipedia.org/wiki/Polyisoprene
Expose it to air, and the double bonds on the surface get attacked by oxygen (ozone works faster) and it isn\'t a polymer any more.
Scrub the surface hard enough and presumably you can scrub off the damaged layer.
Bill Sloman, Sydney
\"stickiness\".  (?)
I have found that amazingly to me that brake fluid is remarkably good at
removing the depolymerised short chain polymer tack from such objects.
It may also alter the surface texture too if it takes too much off.
Test any such solvent on a small patch out of sight and see if it works
for you before risking it on the visible exposed parts.
Basically a combination of ozone and UV exposure degrades these soft
rubbery polymer and short chain stuff is horribly tacky. The hard
polymers tend to be more aggressively crosslinked and seldom fail this
way but in extreme environments they become brittle and craze instead.
(age?).
for \"feel\"?
So:
- what causes this?
It is an intrinsic mode of failure of soft PVC or rubber.
UV and ozone will do for them. The least bad option is to clean it off
with the right solvent which for the things I had was brake fluid.
TBH I only tried it because I happened to have some lying around and a
horribly tacky Psion 3C that was unusable as a result of its tacky
surfaces. Someone recommended it on the Internet - I didn\'t really
expect it to work but to my amazement it did and required much less
elbow grease than any of the other methods I had tried.
Martin Brown
\"stickiness\". (?)
(age?).
for \"feel\"?
So:
- what causes this?
Although most of the items are black, I fine that talcum powder works
well to stop the stickiness. It leaves a sort of pale grey surface, but
it\'s ok by me. You might have to repeat it after a month or two.
I don\'t know what causes it. Oxygen might contribute to the surface
decomposition, but I don\'t think it\'s UV light as I\'ve found it on a
memory stick kept in a box. If it\'s inherent decomposition, I doubt that
anything will stop it.
Jeff
I assume these other \"sticky\" items have a fine coat of a similar
for \"feel\"?
So:
- what causes this?
outcome?
Not all soft plastics experience the \'sticky surface\' failure mode. I
have only seen this failure on soft PVC made with cheap plasticizers.
Polyolefins, neoprene, silicone, polyurethane - I have never seen the
sticky surface failure on these or many others, even after decades of
exposure causing other failures.
Not all soft flexible PVC develops this failure either. While the cheap
clear PVC tubing bought at the local hardware store will, Tygon medical
grade clear flexible PVC tubing does not, even after decades. The
difference is cheap vs expensive plasticizers. (PVC without plasticizers
is rigid.)
I always associate the sticky surface failure with manufacturers who put
cost cutting ahead of quality, and try to avoid them in the future.
\"stickiness\".  (?)
(age?).
for \"feel\"?
So:
- what causes this?
It\'s a combination of decomposition of the main polymer, driven by some
combination of heat, humidity, and UV light, plus the migration to the
surface of whatever plasticizers, fire retardants, and stabilizers that
were mixed into the polymer to improve the polymer properties, plus all
of their breakdown products. Very soft, flexible \"PVC\" can be over 40%
additives and after a few years will steadily ooze \"stickyness\". You
can often find some detergeant or solvent or combination that will clean
the surface but once it starts it will always return, it\'s just a matter
of time. Besides speeding up the chemical decomposition reactions, heat
drives the diffusion to the surface so cold storage is always better, at
least to the point of frozen brittleness :). Welcome to the world of
disposable products.
Regards,
Carl
Glen Walpert <nospam@null.void> Wrote in message:r
On Wed, 7 Jun 2023 09:42:50 +0100, Martin Brown wrote:> On 07/06/2023 06:39, Don Y wrote:>> >> I assume these other \"sticky\" items have a fine coat of a similar>> substance applied to their HARD PLASTIC surfaces...>> for \"feel\"?>> >> So:>> - what causes this?>> - is there anything to prevent it\'s occurrence?>> - why would manufacturers go this route if this was an expected>> outcome?>> - are there other alternatives to alter feel/appearance without such>> applications? (mild textures?)> > It is an intrinsic mode of failure of soft PVC or rubber.> > UV and ozone will do for them. The least bad option is to clean it off> with the right solvent which for the things I had was brake fluid.> > TBH I only tried it because I happened to have some lying around and a> horribly tacky Psion 3C that was unusable as a result of its tacky> surfaces. Someone recommended it on the Internet - I didn\'t really> expect it to work but to my amazement it did and required much less> elbow grease than any of the other methods I had tried.Not all soft plastics experience the \'sticky surface\' failure mode. I have only seen this failure on soft PVC made with cheap plasticizers. Polyolefins, neoprene
, silicone, polyurethane - I have never seen the sticky surface failure on these or many others, even after decades of exposure causing other failures.Not all soft flexible PVC develops this failure either. While the cheap clear PVC tubing bought at the local hardware store will, Tygon medical grade clear flexible PVC tubing does not, even after decades. The difference is cheap vs expensive plasticizers. (PVC without plasticizers is rigid.)I always associate the sticky surface failure with manufacturers who put cost cutting ahead of quality, and try to avoid them in the future.
Its Ozone that breaks down the rubber.
My spare tire brace covering in my truck suffered from this, I
didn\'t know at the time I grabbed it like a hand rail, I had a
hand full of black goo as a result.
I know of no way to recover it, just clean with alchohol, and replace.
Apparently it\'s in how the rubber is formulated.
Cheers
----Android NewsGroup Reader----
https://piaohong.s3-us-west-2.amazonaws.com/usenet/index.html
Do you have an idea what causes the rubber tv remotes are
made of release something oily after some year(s) of use?
I don\'t but I have found a remedy; washing with some gasoline,
a small brush (meant for artists, nonetheless I own some :) to
get to holes etc. revives the thing (the pcb also gets washed,
obviously, it is all covered by oil).
On Tue, 6 Jun 2023 22:39:12 -0700, Don Y <blockedofcourse@foo.invalid>
\"stickiness\". (?)
(age?).
for \"feel\"?
So:
- what causes this?
Very likely the \"rubber\" is urethane-based , and is depolymerizing.
This is called reversion, as in the rubber polymer reverts back to the
monomer from which it was made.
Joe Gwinn
damaged layer.
It is silicone grease, caused by defective curating of the membrane.
Ethanol and cotton are very effective.
Saludos
Miguel Gimenez
for \"feel\"?
So:
- what causes this?
Although most of the items are black, I fine that talcum powder works well to
stop the stickiness. It leaves a sort of pale grey surface, but it\'s ok by me.
\"Why would manufacturers go this route it this was an expected outcome?\"
Surely, there are other materials and finishes that could be used.
Is <whatever> less expensive than the plastic onto which it is *applied*
(these look like COATINGS with the thickness of a fine layer of paint;
yet are quite obviously not part of the underlying material to which
they were applied)
I.e., what ADVANTAGE to this approach?
[It may, in fact, just be a \"spray on MATTE finish\" to avoid having
to acid etch a mold for \"texture\"]
The \"rubber\" (rubbery?) button on my electric toothbrush shows this
degradation -- but the similar material that totally surrounds the
device doesn\'t. Either a different material (?) or different
use pattern? (my hand spends more time in contact with the material
surrounding the device than it does with the on/off button)
decomposition, but I don\'t think it\'s UV light as I\'ve found it on a memory
stick kept in a box. If it\'s inherent decomposition, I doubt that anything will
stop it.
\"stickiness\". (?)
Alcohol, glycerine, and brake fluid (which is mainly a heavy alcohol)
all work. Isopropanol is volatile enough that you can\'t wipe it on
and let it sit, but have to rub vigorously to clean.
But with some items, may recur.
\"stickiness\".  (?)
removing the depolymerised short chain polymer tack from such objects. It may
Yikes! Brake fluid will take the paint off metal! :-/
Test any such solvent on a small patch out of sight and see if it works for you
I have a go-to list of solvents that I use, based on the material
being removed (and past experiences with it or similar) AND the
underlying material. E.g., I will clean glass with more aggressive
solvents than I would use on plastics.
In (general) order:
- soapy water (dissolves may glues used for labels)
- alcohol
- mineral spirits
- WD-40 (et al.)
- gasoline
- acetone, mek, xylene (et al.)
- mechanical abrasion (e.g., rotary wire brush)
Basically a combination of ozone and UV exposure degrades these soft rubbery
polymer and short chain stuff is horribly tacky. The hard polymers tend to be
more aggressively crosslinked and seldom fail this way but in extreme
I\'m not sure THIS is \"rubber\". In the past, my experiences have been
with \"rubbery\" substances... things that were large enough that you could
actually apply pressure and see (intended) deformation -- like \"feet\"
for devices.
These instances appear to be surface coatings. They tend to alter the
appearance of what would otherwise be \"glossy\" plastic parts. There
MAY be a slight change to the feel imparted but nothing that you
would think of as \"rubbery\" (in terms of deformability).
E.g., I noticed the logo on some of my GPUs is presented on a surface
that has a similar treatment; I can\'t imagine it\'s purpose, there,
would be to alter the *feel* of the PCI card. And, it doesn\'t affect
the item structurally as the cards are supported with deliberate
mechanical devices -- not logos! :>
(age?).
for \"feel\"?
So:
- what causes this?
Is this, then, just a different application of those BEYOND use
as \"feet\"? If so, why not some other substance (or PROCESS)
to achieve the same *visuals*/feel?
UV and ozone will do for them. The least bad option is to clean it off with the
We use a lot of (recycled) glass containers/jars for storage as they
aren\'t oxygen permeable. A quick soak dissolves paper labels allowing
them to be scratched off with a fingernail. The glue residue coming off
with a mild mechanical abrasive or mineral spirits (later washed with
alcohol and then soapy water before being used for foodstuffs).
\"Property (inventory) tags\" are most often encountered affixed to
metal surfaces so gentle prying (many are made of metal themselves)
followed by spirits or acetone (if the surface isn\'t painted).
Many solvents will take the \"gloss\" off of plastics. Likewise, vigorous
rubbing. This makes the resulting surface look \"used\".
TBH I only tried it because I happened to have some lying around and a horribly
tacky Psion 3C that was unusable as a result of its tacky surfaces. Someone
recommended it on the Internet - I didn\'t really expect it to work but to my
amazement it did and required much less elbow grease than any of the other
But, will the \"condition\" return?
\"Why would manufacturers go this route if this was an expected outcome?\"
\"stickiness\". (?)
I \"cleaned\" a mouse with such a coating -- by removing the coating!
Now, the mouse has a *glossy* plastic finish instead of a *matte* one.
I\'d be hard pressed to identify which had the coating (prior to the
stickiness phase) and which didn\'t, based solely on feel.
I don\'t expect to ever need to \"clean\" it again.
IMO, the manufacturer could have textured his molds to give a similar
appearance/feel to the mouse without the \"risk\" of this silly coating.
Or, the recurring cost for the material applied.
for \"feel\"?
So:
- what causes this?
outcome?
It\'s not always a \"surface\" phenomenon. E.g., the feet on Sun workstations
turn into a gooey substance that makes used chewing-gum-in-the-hot-sun
look like a trivial mess to clean, by comparison!
And, would surface *coatings* be of similar composition? Are there
alternatives (regardless of cost)?
is rigid.)
How do you ascertain whether a product is *coated* with a material
that might degrade thusly? Do you assume manufacturers never
improve their products/processes?
E.g., an nVidia GPU used a similar material/coating. Ditto a MS mouse.
I don\'t see a rationale for *either* to have made these choices, except,
perhaps, ignorance of the long-term consequences of their choices.
[I want to skip forward to that point where this outcome does not apply]
(age?).
for \"feel\"?
So:
- what causes this?
combination of heat, humidity, and UV light, plus the migration to the surface
of whatever plasticizers, fire retardants, and stabilizers that were mixed into
the polymer to improve the polymer properties, plus all of their breakdown
products.  Very soft, flexible \"PVC\" can be over 40% additives and after a few
Would something \"soft (fluid) enough\" to be applied as a *coating*
be such an example? Or, is this a different substance, entirely?
You can often find some detergeant or
solvent or combination that will clean the surface but once it starts it will
always return, it\'s just a matter of time.  Besides speeding up the chemical
decomposition reactions, heat drives the diffusion to the surface so cold
storage is always better, at least to the point of frozen brittleness :).
Welcome to the world of disposable products.
The point of my question is not to \"fix\" devices that I have that
are exhibiting this problem. Rather, to make sure I don\'t *design*
devices that will exhibit it!
You wouldn\'t KNOWINGLY put knobs on a device that would \"become
sticky\" with age.
I.e., the \"why would manufacturers go this route if this was an
expected outcome?\" especially if \"other alternatives to alter
feel/appearance without such applications\" exist. How many
micropennies do you have to spend to avoid this problem? Or,
is it unavoidable -- that <whatever> reason the manufacturers are
chosing to go this route can only be addressed *by* this technique?
So, all urethane-derived products/materials/coatings would exhibit a similar
problem?
Are there alternatives to these?
Joe Gwinn
If you have removed the offending surface layer then that is probably
the case. Most things that have this stuff on usually have an MTBF that
is broadly comparable with the failure of the soft rubbery plastics.
That sort of soft fleshy feel was in for a while. Manufacturers adopted
it without worrying about the cheap plasticisers allowing polymer
degradation on a ~5-10 year timescale depending on ozone levels.
Most kit is replaced on a shorter timescale and so it is non-problem.
(for the manufacturers)
Martin Brown
for devices.
I\'m using rubber here in the generic properties sense including anything
plastic that is slightly soft to the touch as opposed to strongly
crosslinked and rigid engineering plastics.
Some paints are very similar formulations.
So:
- what causes this?
It almost never fails within the period of warrantee. Marketing types
seem to like the soft touch feel of the rubbery plastics. I never really
liked it - dead flesh style waterproof keyboards put me off for life!
Martin Brown
You can often find some detergeant or solvent or combination that will
clean the surface but once it starts it will always return, it\'s just
a matter of time.  Besides speeding up the chemical decomposition
reactions, heat drives the diffusion to the surface so cold storage is
sticky\" with age.
Because they want the customer to buy another one every 6-8 years and
they expect many to have failed or be replaced before the surface
coating even becomes an issue. Hotter, or humidity, and high UV all
accelerate the damage to softer plastics.
Better plasticisers can make it last much longer but in most cases price
is everything and so you get what you pay for.
Martin Brown
